Foxman
Hello Guys,
Just wanted to probe the community to see what might be causing my front end knock problems. I just did the 20,000 mile service and sent my forks in to the local Indi who does good work to re-fill my cartridge shock. Before I took the front end appart, I had a knocking noise in the front end when going over big bumps in the road. the forka weren't bottoming out or anything, but I figured it may have been the steering head bearings. after having the forks drained and re-filled (with OEM HD recommended weight oil) and doing the steering head bearing tightening procedure (Which I must say is a little Hokey) I eliminated all play in the steering head bearings without putting pre-load on them... The knock is still there, and I am out of ideas on what could be the cause of the noisy front end. If I press really hard on the handle bars while holding the front brake at a stand still, I can get the noise to happen. Slight bumps don't generate the knock, only large bumps Living around the Detroit area, that means I hear a lot of knocking on a daily ride...
Any suggestions would be appreciated in my diagnosys!
