a rear brake switch and a front
A P0132 is the Front cylinder running rich for too long of an operating time.  A P0152 is the same but only for the rear cylinder. The ECM is not seeing the O2 sensor toggle from lean, back to rich, back to lean etc.
Anything that would cause the engine to have a FIXED A/F ratio lower than 14.3 for an extended period of time will toggle those 2 codes.
Thing such as an out of calibrated cylinder head temp sensor, out of calibration MAP sensor, excessive fuel pump pressure, lack of air flow through the air cleaner, poor cylinder combustion due to ignition problems etc etc.  You get the picture. Anything which would push the A/F ratio to the rich side (and keep it there) would do it.
But first the service tech needs to confirm the theory using a scope on the O2 sensor outputs.  If the O2 sensor output waveform does not toggle rich,lean,rich,lean over and over again with around a frequency of 1HZ,,, (60 times a minute) that is your problem. The Digital Tech the dealership has should show an O2 sensor toggle action.
I doubt a Stage one MAP would help. That would only push it more to the rich side.
Since BOTH cylinders are running rich, I would doubt both injectors are bad or leaking. Since it is BOTH cylinders, you would have to have multiple issues with the wiring harness for this to happen. So my guess is that the wiring to the O2 sensors is OK.
Need more info to narrow it down.
You did not answer the question about having ANY type of enrichment fueler.
You did not say if you have seen ANY other codes other than the O2 codes.
What does "a rear brake switch and a front" mean? Codes for switches?
Other than having the codes,  how does the bike run? Does it pull hard without a miss?
