I've done several searches but haven't found any type of answer for this repair. Security light on with no security system on the bike. No speedo or tach but both will sweep in test mode. Initially I got a U-1255, U-1016, U-1064. Cleared codes and only the U-1255 came back. Replaced the VSS but thought about it afterwards that that shouldn't effect the tach. All fuses good and power on the 2 different terminals that have any common relationship to the units. If the signal to the tach comes from the crank sensor can I test its frequancy reading with a multimeter? Also if there was a problem with the crank sensor, wouldn't that effect starting? I'm tending to look at the TSM unit but don't want to replace a good part until I know for sure. HELP.
Buster
Buster
