free website stats program 06 primary part# | Harley Davidson Forums
06 primary part#
maine-e-axe
Junior Member
Can anyone give me the part# for a 06 SB primary gasket? And has anyone tryed welding the screw's on the rotor inside the primary before they loosen up and rip up the stator, I been thinking about Heli arc the screw's to stop them from backing out? Thank's in advance
I tig tack welded the rotor screws last year. They were not loose but why take a chance. While you have the primary apart, check the bearing and race on the trans mainshaft through the inner primary. It may need attention. Mine did.
I googled '2006 dyna primary gasket part no'.I came up with an article from "Hot Bike Baggers" that listed the following:
Primary cover gasket-60539-94b
Clutch cover gasket-25416-99c
Inspection cover gasket-60567-90c
Inspection cover bolts-63859-95b
Is this what you want-i'm not sure?I'm merely taking a guess based on your choice of repair work and model year.
Hope this helps.
