Hello all. I just bought a 2006 Street glide that had 19500 miles on it when i got it it now has 22579. When purchased it had python mufflers and a K&N high flow air filter. I installed a fuel pak and everthing was great. I then put on 12 in bagger apes and changed out the clutch cable to make them fit (Was able to reroute throttle and brake) I just took it for a 1400 mile road trip and it is running way rich. Able to smell it crusing at 90. about 400 miles in i disconnected the fuel pak with no change. My buddy also has a 06 street glide and he could not ride behind me because of how rich the bike is running. We both got the same milage. 36-42 depending on how hard we rode. I just just checked for codes and have a P0505 Idle control fault. Idle control seems ok except on cold starts if i don't let it warm up a bit before giving it gas it will not idle for the first couple blocks (also started after bar install) I am at a loss. Could throttle cable adjustment cause this?
