Take it apart, check the connectors to see if they match up. Turn the key on, if it lights up, it probably will work. I just saw one yesterday on E-Bay that "says" it matches up. Yours, I think, has a wire that runs to the speed sensor, located behind the rear jug, on the right side of the tranny. Does your original speedo light up and show current miles, "A" & B" trip destinations, bring up trouble codes? If not, the 1st thing i'd check is the speed sensor. Cheap enough to replace, 'round $49.00.
