09 Road King, 41000 miles. Starts strong, runs fine, but as I ride the motor feels as if its starving for fuel when I call for power. Especially at highway speeds, if I'm running 80 in 6th gear and slow down to 70, it feels as if I am lacking torque to get back to 80, however it can be felt on city streets as well. When I first start the bike and head out it is strong and seems to lose power gradually, like a loss of fuel pressure. My fuel economy has also dropped from about 34 to about 30 mpg since the problem got noticeable.
I bought the bike 4 months ago and have put 7000 miles on it, and the loss of power seems to be getting worse since I started riding it. It had been suggested by a mechanic when I bought the bike that there may be a pin hole and loss of fuel pressure in the lines in the tank. I opened the tank and removed the top plate, replaced the fuel filter and inspected the lines but saw no damage or places where lines would rub. I attempted to run the pump and check the lines for leaks but it appeared as if the regulator was spraying fuel and I couldn't make out any leaks.
It has electronic throttle, V&H Fuelpak, stage 1 air cleaner and true duals. It was throwing codes for running rich in both cylinders, I called V&H for lower values and since then it has thrown no codes.
I changed the plugs, and a Blackstone Labs oil analysis done last week shows no out of range metals, leading me to believe the rings are not blown, though I would probably need compression test to confirm that, and since I am not burning excessive oil or smoking I'm thinking I can rule that out, particularly with the relatively low miles on the motor.
If anybody's got any suggestions, I'm not sure what direction to go next to figure this out...
