Potato Man
I know there are posts about installing risers, but I have an 09 RK with the fly-by-wire throttle wires inside the bars. I went to the dealer and they had a hard time coming up with a riser & longer clutch, brake cable setup, and , there are no throttle wire extensions in the book. I DID find throttle wire extenders on ebay, cheap; but I was wondering how much throttle wire slack is in the nacelle ? If there is at least 4" of slack then maybe I don't need to extend the throttle wire cable.
If anyone has successfully installed the 4" risers, riser plate, and all the extended clutch, brake cables and throttle wires , I would appreciate some help.
Thanks
Thanks
