forsakenZen
Looking for input on an odd turn signal issue.
94 FLHTC, I added LED signals (with load equalizers) to the front everything was working fine. Had to pull the front fairing off to do some other work inside so I disconnected the headlight and signals and set aside. When work was done I reconnected everything but signals now do not work, the rear signals come on and stay solid but no front signals, the hazards work as well, the front LED's light up if I apply a charge directly to them so I know the LED's are good, I even replaced the load equalizers with new ones and still no flashy flashy.
Any thoughts? And thanks in advance for your help.
