free website stats program 99 ultra engine light at start up | Harley Davidson Forums
77pronova
i have a 99 ultra that is fuel injected,at strart up the engine light comes on and stays on for 5-10 seconds.the bike runs fine i just wondered if any one knows what causes this.
That's normal, mine does it also. If you turn the ing on & wait, does it go out quicker? You could try to pull codes & see if there is anything in there, but like I said, I think that is normal for the 99's.
Toby
Normal, going through a self check just like your car does:s
it has always came on when you turn on the ignition but would go out,now after it goes out it will come on again about 10 seconds later and stay on for 5-10 seconds then go out again.
Steps:
Disarm alarm if so equipped.
Run/Off switch to OFF
Ignition Key: ON,OFF,ON,OFF,ON (and leave ON)
Press LEFT turn signal switch TWICE. Wait for 1 or 2 flashes..(either 1 or 2 is OK)
Press RIGHT turn signal switch ONCE => turn signal will flash 1 time
Press RIGHT turn signal switch ONCE => turn signal flashes 2 times
Press RIGHT turn Signal switch ONCE => turn signals flash 3 times
Press LEFT turn signal switch ONCE. TROUBLE CODES WILL NOW BE DISPLAYED (stream)
TO CLEAR ANY CODES,,,=> PRESS & HOLD LEFT signal switch for 5 seconds. => turn
signal will now flash twice to confirm memory is clear.
Turn ignition OFF.
Try this
Yep, you have a stored code. Here is a list of the codes. Use this chart after doing what Jack posted. There are a few more if you have cruise control.
Diagnostic code No. Fault condition
11 Throttle position sensor (EFI)
12 MAP sensor (carbureted)
12 Barometric pressure sensor (EFI)
14 Engine temperature sensor (EFI)
15 Intake air temperature sensor (EFI)
16 Battery positive voltage
23 Front cylinder fuel injector (EFI)
24 Front cylinder ignition coil
25 Rear cylinder ignition coil
32 Rear cylinder fuel injector (EFI)
33 Fuel pump relay (EFI)
35 Tachometer (except FLHR, FLHRCI)
41 Crankshaft position sensor
42 Camshaft position sensor
44 Bank angle sensor
52 RAM error or failure
53 ROM error or failure
54 EPROM error or failure
55 Ignition module failure
56 Camshaft position sensor and crankshaft
position sensor timing or signal error
