free website stats program 99 wide glide cv carb trouble | Harley Davidson Forums
flagator1
cleaned the carb and now it kinda bogs down at full throttle. the throttle response is just not there any ideas
If you opened up the diaphragm in the top whew you did the work that's where the problem is, It's not seated correctly.
Did you make sure and get the diaphram lined up and not pinched? This is a common problem with the CV carb and it's hard to get it back together. See if the needle travels
without binding. Also the membrane could have a hole in it but I bet it's just not traveling free. I'm talking about the one on the top of the carb under the cover, not the one on the accel. pump.
Can't get faster than that Glider, he's on it!
I replaced my carb on my 98 fatboy with a Mikuni, at the age of the bike it was needing rebuilt or replaced. I love the carb, food for thought. Cheers:)
