banjo picker
did anyone alter ( open up ) their air cleaner housing when you installed your K&N or SE a/c? Thanks for any info/input. BP
good morning Glider.I installed the TFI,the slip-ons,and installed the K&N a/c as well.I do have the stage 1 up grade.The info I got was the K&N opened up the air flow to support the s/o's and the TFI.So is it necessary to alter the stock housing that houses the K&N filter on my 103"? Thanks for any info. BP
You are fine. The kits that come with a new back plate are intended to eliminate the football back plate. I have 3 old back plates in my garage that I should throw into the recycle. :s
