free website stats program abs light on after brake and tire replacement | Harley Davidson Forums
Joel Sims
Recently i replaced the front tire and brakes on 2008 Ultra. After reinstalling the wheel, the abs light flashes and stays constant after riding. I had the sensor replaced at the stealership about 2 months back.
Sounds like something didn't get put back togeather right or got broken. Re check the harness connection and sensor position and ohm test it.
Are you sure you replaced it Left as left, and right as right sides? The sensor may be on wrong side. Also, the wire is delicate, make sure it's not damaged.
