free website stats program "Add on" parts list | Harley Davidson Forums
"Add on" parts list
cdn-bigfoot
Junior Member
Have you ever tallied up all the aftermarket parts you've put on your bike?:newsmile105:
I just did. Uuuuuh. How did this happen?:newsmile07:
2006 Harley Davidson FXDBI Street Bob
2007 Victory Vegas Jackpot front billet aluminum 5 spoke 21” wheel “Monaco” (2.15” rim width)
w/ Metzeller ME 880 120/70-21 bias ply tire
2004 Harley Davidson Deuce chrome 17” solid rear wheel
(4.5” rim width)
w/ Metzeller ME 880 170/60R17 radial tire
Kuryakin Hypercharger - chrome with K&N high flow filter
HD Airfoil grips
HD Airfoil extended pegs
HD Airfoil Shifter peddle
HD Airfoil passenger pegs
HD passenger peg mounts
HD Airfoil vented derby cover
Custom chromed dash and ignition switch
Cobra Speedster shorts pipes w/quiet baffles (also have loud baffles)
Cobra FI2000R Closed Loop fuel injection controller
Memphis shades “slim” quick detach windshield.
HD 2-up seat
HD Streetbob solo seat (stock oem)
HD quick detach sideplates
HD “low” backrest with Willi G Skull badge
HD 5 bar chrome luggage rack
Motherwell chrome rear fender mount luggage rack
HD LED 6-shooter fuel gauge
HD 6-shooter fuel cap
300mm full floating front brake rotor - Victory part
HD chrome battery box band
HD Street Slammer bar w/internal wiring
HD front signal relocate to top triple tree
HD smoke signal light lenses all around
HD signal light visors all around
HD rear signal relocate to plate holder
HD CVO FatBob mirrors
Kuryakin smoke LED laydown tail light
Leather quick release sideplate mounted saddlebags
Leather fork bag
Barnett Stainless steel braided Throttle and Idle cables
Barnett Stainless Steel braided front brake line
HD “Willie G Skull” front axle nut covers
HD “Willie G Skull” rear axle nut covers
HD “Willie G Skull” license plate bolts
HD 2007 Night Train tank badge
HD Chrome fender struts
What have you got on your ride?
Let's see a picture.
So you went with the Metzeller ME 880 170/60R17 radial tire. You did not change your aspect ratio after all.
scary aint it CDN when you add it up - but when you look you cant see all youve added and wonder were the money all went LOL
I am sure you have seen the bumper sticker that says,,
"I spent 90% of my money on Wild Girls and Booze. The other 10% I wasted"
Just a few trinkets for me....:D
  • Fender skirt V Logo
  • Kuryakyn extended heat shield
  • Billit shift linkage
  • Billet shifter levers
  • Shift pegs (2)
  • Billit brake lever
  • Brake pedal
  • Head bold covers
  • Caliper inserts
  • Front Floorboard covers (top)
  • Rear Floorboard covers (top)
  • Rear Floorboard (underside)
  • Soft lowers
  • Saddlebag guards
  • FLHR Stem clock
  • Banjo bolt covers (4)
  • Air pump (shocks)
  • Kuryakyn tail light cover
  • Kuryakyn Dash insert
  • Kuryakyn Regulator cover
  • Stage 1 Intake
  • K&N HD 0800 filter
  • Chrome fork air baffle
  • Dash panel complete (kury)
  • Clutch cable P Clip
  • Chrome reflector housings-frame
  • Rear aux brake/running lights
  • R Brake mounts
  • Kuryakyn cylinder base cover
  • Kuryakyn mid frame chrome covers
  • Chrome Drain screws
  • Timer cover
  • Chrome rear foot peg base kit (FLHX)
  • Rear passenger pegs (replaced boards)
  • Peg Mount bolt kit (chrome)
  • Isolated Drive System
  • Front bullet turn signals
  • Front Visors for above
  • Rear Turn Bullet Bar
  • Rear visors for above
  • Rear red lenses
  • Passing visor bezels
  • T/S visor bezels
  • Headlamp bezel
  • Chrome rear Master Cyl cover
  • Chrome Transmission interface
  • Chrome handlebars
  • Chrome clutch cable ferrules (2)
  • TFI (1250ST)
  • Alarm smart siren
  • License plate frame
  • Gerbing heated gloves
  • Kury Inner primary cover
  • Kury Lizard lights
  • Frog mouth neutral switch cover
  • Chrome Starter solenoid end cover
  • Chrome Tri bar LED Rear fender tip light kit (FLHX)
  • Caliper insert (oil cap)
  • Trans dip stick CH
  • Chrome FLT front-end package
Chrome fork kit-sliders/cowbells
Axle spacers/axle covers
Chrome hand levers
Chrome master cylinder & clutch perch
Chrome front master cylinder cover
Aileron grips
Chrome switch housings
Chrome switch bolt kit
Harness retainer
Ok, once of these days I will post a updated pic.
Already on when I purchased it.
  • Thunderheader Exhaust
  • Stage I - Big Sucker
  • Fin covers all around
  • blacked out forks
  • blaked out handlebars
  • Kuryakn flush mount gas cap and gauge
  • Mothers solo rack
  • Chrome Headlight Trim Ring
  • probably a few more that I am just not aware of too
Then added by me.
  • Black Typhoon Wheels, front and back
  • Wide Tire Kit
  • Screaming Eagle front tire
  • Mustang Day Tripper Seat
  • Gloss Black forward controls
  • Smoked Lenses, front and back
  • Black Diamond Foot pegs
  • New Black Fin Derby Cover (since I scraped the other one on a drop)
  • Quick Detach Tinted Windshield
  • Windshield Bag
I don't even want to look again at the list I have running for the stuff I want, the stuff I need, and the stuff to make it 2-up. That list is currently around another 2K which I will be chipping off slowly over the next couple years.
Jeeze; Compared to some, I'm almost bone stock. :D
fork wind deflectors
shift shaft cap
windshield organizer
tour pack antenna
docking kit
quick detach rack
klever lever
8" dark smoked windshield
seat pin
saddlebag latches
streamliner shift peg
streamliner brake pedal
soft lowers
windshield tri
fork air baffle, black
contour windshield
Y cable for radio antenna
Teclusion/Doebuck TFI fuel pack
oil temp. gauge
screamin eagle air filter assy.
Kuryakyn ISO grips
garmin handlebar mount
hot toppers bolt cover kit
gap heat shield
chrome timer cover
Fiamm? hiway blaster horn
Rush slip on mufflers 1.5" baffles
Going to stop throwing goodies on my 07 Streetbob, The Mrs. says if we pay off her Rav 4 I can get a Trike, so motherswell fender rack HD engine guard, cycle shack turn out exhaust SE wires and plugs is all its going to get as I will give the Dyna to The Boss when I get the Trike:s
