Neal Spranger
Purchased the Harley adjustable backrest and spent the last 3 hours trying to get the thing installed. My hangup is that there were no nylon washers or threaded studs sticking up out of the two holes in the fender like I see on most examples on the web. This is where I'm to mount the hardware. SO, the problem is that I cannot get the flanged bolts up under the fender, through the holes (actually on hole and a slot hole) and get them through the mount and get nuts on them because I cannot get my hand or a wrench up under the fender to reach the bolt head due to such a narrow clearance between the fender edge and the tire. I was actually able to use a small wire wrapped around the bolt to fish it through the hole, but the nuts are lock nuts so I have no way to keep the bolt from spinning when trying to get the nuts on. Sure wouldn't think I would have to remove the tire or anything. I also tried putting it on a cycle stand to let the suspension drop the tire down, but that didn't do anything. I also put 25 lbs in the shocks (max according to owner's manual) but that too did not increase the clearance between the fender and the tire. Any suggestions or similar experiences out there to share - hopefully with some advice or a sure-fire fix??? I would be grateful since it was over 70 in central wisconsin here today and I told myself I wasn't going to ride till I got the highway pegs on and the backrest!:sd
