banjo picker
has anyone re-located your air valve for your rear shocks?My air filler valve is too short to get an acurate reading when I put the air to them. thanks
I have my bags adjusted just ever so slightly blocking the service valve. As you say the notch is there but in my case it is not dead on in alignment.
On my 2008 EG I have to remove the left saddlebag. Not hard to do as it is just two quarter turn dzus fasteners and it is off. I use the HD Air Pump and I can't service it without removing the saddlebag.
Relocating the service valve will run a risk of leaking IMO.
Just in case you aren't aware or others that are reading aren't, the air suspension in a touring bike should not be serviced with anything like a gas station air hose or you will damage the system.
I recommend the HD air pump...
