cyborg Active Member Jan 31, 2015 #1 Bought a set of Arlen Ness Polyurethane Busting Kit. They won`t fit in the Triple Tree. Any hints on getting them in?
J Jack Klarich Guest Jan 31, 2015 #2 cyborg said: Bought a set of Arlen Ness Polyurethane Busting Kit. They won`t fit in the Triple Tree. Any hints on getting them in? Click to expand... The polly bushings are alot stiffer than stock, if they are TOO tall, try freezing them
cyborg Active Member Jan 31, 2015 #3 Jack Klarich said: The polly bushings are alot stiffer than stock, if they are TOO tall, try freezing them Click to expand... Not too tall, there too Fat. If you put them end to end (new one and old one)you can feel that there a hair or two larger.
D dbmg Guest Jan 31, 2015 #4 Is this the part you purchased? Arlen Ness Polyurethane Riser Bushing Kit - 08-005 If so then try Jack idea for freezing will also make bushing smaller.
