free website stats program Best grip glue | Harley Davidson Forums
Best grip glue
stevec314
Hey all,
I got my new grips on and followed the instructions and it was so easy. My only problem is that the "death Grip" glue that came with the grips, was dry and no good. What do the experts recomend for glueing that grip on? I tried some DAP that I had but it didn't hold to well. I might have not shaken it good enough.
Steve
I have used "super glue" when putting on Kuryakyn ISO grips. The technical term is cyanoacrylate. My suggestion is to use a slow setting, gel consistency type. This will allow you more working time to align the clutch side with the throttle side. Only downside is removing the grip, should you decide to. Will probably have to destroy the grip.
Hope this helps
Hey all,
Steve
Don't laugh, but I use the same stuff I use for my golf club grips!! You wrap the bar with some double-sided masking tape (grip tape), and squirt it with a solvent that softens the adhesive on the tape side that is showing. Then you put your grip on twisting left and right as you apply it. Wipe off the excess that gets pushed on by the inside edge of the grip, and let it set up (dry). It will be ON THERE!!
Same thing happend to me. Bought the Kuryakyn Iso grips and the glue was hard as a rock. I used Gorilla Glue and it worked just fine.
I have heard of using hair spray and even spray paint.I used epoxy cause I wanted my new grips on so bad and that was all I had.I was slow on the clutch side and (EDIT) near had that grip turn solid half the way onto the bar.My adrenaline kicked in and it went in place.Pity the guy who wants to change them.
Please read...
[notes]
[/notes]
