Dark Horse
Have any of you guys fitted a front brake piston / seals ( the one in the fluid reservoir , NOT in a caliper) on an ABS equipped model , and then gone on to successfully bleed the brake afterwards ?
I'm aware that the proper procedure necessitates the use of Digital Technician 2 , but I don't fancy shelling out another £100 after only having the job done last year by my local Harley dealership ,(they also replaced the fluid) , and I've read that using Digital Technician 2 is only to fully ensure 100% that no air remains.
I've heard or read that the job CAN be done without the Tech equipment but never been able to find out whether there's a technique !
Since the work involves only the highest point of the braking system , surely any air would rise into the fluid reservoir , in which I would hope to retain enough fluid to prevent air entering the system.
The piston / seals were replaced last year due to the brake light staying on after the lever was released. This totally cured the problem at the time.
Surely the problem shouldn't reoccur after such a short period of time !
My bike is a 2013 Fat Bob (ABS)
Regards
Regards
