Be sure you know WHAT is in your bikes' brake systems now, and what is SUPPOSED to be in there. Your brake system is not something to guess at. If you don't know what is in it, start from scratch. If you are even a little unsure, the safest thing to do is to COMPLETELY disassemble the brake system, clean out everything including the lines, chase/clean with alcohol, and blow them out with dry air. Reassemble everything using fresh brake fluid as the oring lubricant for assembly. Make sure it is the right fluid for THAT bike's brake system. Bleed the brakes using the method you like the best (I like to go from the bleeder valves to the reservoir on the front, and from the reservoir to the bleeder valve on the back, and use a vacuum bleeder on the back if you have one). Both my bikes use DOT 5 fluid which is silicone based - NOT compatible with DOT 3, 4 OR 5.1!! DOT 5 is not hydroscopic or at least not like glycol based fluids are. AND, DOT 5 is NOT compatible with the other fluids (notice I repeated this!!!).
This is one of the most important systems on your bike. Don't mess around. Do it right. If your fuel system or your ignition system doesn't work, the engine may not start or run right; if your suspension system messes up, you may not like the ride; if your brake system malfunctions ... well you get the message!!
