If everything checks with your front brake switch after lever readjustment and you are assured the switch is not broken from your grip install. Then, it may be your master cylinder is corroded and not providing enough force from the plunger to the brake lever to keep the switch closed when the brake isn't applied.
Either way, you have an open switch condition, whether the switch is broken or the brake lever is not making contact with the switch.
