free website stats program Brake peg to high; mini foot boards temp solution | Harley Davidson Forums
geislert
Banned
I have been having problems with foot placement on my Fat Bob brake peg since it sits a couple of inches higher then the gear shift peg and I am 6' 4". I found a temporary solution until I can figure out how to drop the entire assembly a couple of inches; the Kuryakyn Iso-Wing Mini Boards. They bolted right on and were rotatable so I could get the proper clearance to the controls.
Anyone have a suggestion on dropping the entire brake and peg down?
Rear brake pedal has about 1/2" to 3/4" adjustment up and down. The adjuster is located back on the master cylinder for the rear brake. Just follow the linkage, you will find it. Hope it helps.
