Here's a cut 'n paste I found on the web. I can't verify the accuracy of the information. I had mine replaced, I didn't do it myself. Make sure you file the edge of the pawl before installing new spring. The sharp edge is what causes the spring to break.
Subject: shift pawl centering spring replacement procedure #8
From: "Patrick \"hogdoctor\" Zambori" <hogdoctor@centurytel.net>
feels like I've done hundreds of these things and as time is money in
the wrenching field, I've learned how to do it
-fast-
takes some talent though. aka patience.
if you have no other obvious reason to take the inner primary drive apart,
then leave it alone. Takes too much time and too much potential for creating
a problem that doesn't currently exist.
extract the transmission top cover and whatever else is in the way of it.
If the starter is in the way, just blow the two bolts holding it to the
inner primary, pop it loose and rotate it clear of the trans top. If it's a
softail, unbolt the oil tank and swing it out the right side. no need to
drain it nor disconnect any lines.
next yank the exhaust, clutch release cover, shift drum, forks and fork
shaft.
unbolt the door from the trans housing. Remove the nuts from the main and
countershafts.
now heres where the special tool comes into play.
It's a crossbar that bolts to the trans door and pushes the main and
countershafts out of their bearings. You can use this tool to extract the
door and bearings from the shafts and transmission. The bearings will need
to be replaced after this is done.
remove the spacer, first gear, clip and shifter clutch from the main shaft.
At this point, the countershaft in it's entirety can slide right out of the
transmission.
now move to the shifter. Unbolt the shift rod from the trans shift arm,
remove the pinch bolt from it too.
make a note as to the position of the arm relative to the shaft so you can
reinstall it in the correct location on the spline.
slide the shifter arm as far off as it will go, then reach in with a pick
and grab hold of the circlip, and rip it out with wild abandon. Now you can
pull the shift shaft inward and free of the bushing.
Install the new spring, and stuff it back in so the shaft barely protrudes
through the seal.
with deft precision, use a 90degree snap ring plier to install the snap ring
about 1/4 inch onto the shaft, then sneak the shift arm back into there,
then push the shift shaft the rest of the way into place, push the shift arm
onto the shaft to slam the cirlip into place then reinstall the pinch bolt.
now, reinstall the countershaft and mainshaft parts , replace the bearings
in the trans door, then use the shaft end nuts to pull the door back onto
the transmission.
Reassembly is the reverse of
disassembly at this point.
remember to look for the piece of spring that came off when it broke, and
check the teeth for bends.
If you recover all the spring parts with no dents in them from going through
the teeth, you're fortunate.
