I had new cams/ bearings, tensioners, lifters, push rods, oil pump and a Dino tune job. Also had leaking rocker box seals fixed. In addition I had the primary cover removed to inspect the compensator with the Compensavor.
First ride review.
The bike pulls stronger and has a better and wider power band width. It is also quieter. The guy that tuned the bike must have moved the red line up because it doesn't cut out where it did before.
Mongo
