Guess it would be a matter of time before I would do it. looking to keep this bike around awhile so I know I will have to do a top end one day. Just trying to pick the best cam for what I need.
You NEED to look at compression NEEDED to opperate the motor properly with your cam choice.....
BIG Cams LOWER compression in a stock motor.(later closing valves)
IF you do Cams ONLY like Bolt-ins... Lower intake Close numbers are needed for a stock motor than the later numbers on Big Cams....
Without head and valve work, larger bore AND/OR raised compression,
BIG Cams Just Won't Work Like Wanted and Needed.
Mouse Cams like andrews 21's and 203, 204 cams work great in stock 88" or 95" motors...
any larger will NEED Higher Compression NOW.
The motor will not perform like I would want it, without adding compression..:newsmile093:
To Judge a cam,,,,LOOK at the intake Close of the cams design... Anything above 36*/38* in MY book WILL need substantial compression increases to put a smile on your face.:newsmile011:
You Miight want to Just Wait until you can do the Job PROPERLY....:newsmile055:
