Ultra Will
Just wanted to post what happened to me and hopefully avoid the same thing happening to someone else.
I lowered my bike about an 1-1/2" with a lowering bracket.
Not only does it look nicer to me but my feet are more comfortably planted on the ground.
Anyways, my wife is roughly 130 lbs and I really did not think about the need to add more pressure to the air suspension after having it lowered.
After about 5-6 months, my rear right turn signal stopped working.; as did my rear right stop light... The rear right running light would still work so that became puzzling. I ended up having to take it to a local Indy.
After searching the bike over & over and a few hours labor time ($$) it was found that my wiring harness that runs inside the rear fender had been rubbing against the tire and a few of the wires and been stripped and were actually touching each other...
So if you're considering a lowering kit, remember that harness thats under the rear fender. You'll either have to re route that harness elsewhere or keep a constant eye on that suspension's Air pressure. I'm keeping it at 20 lbs and I told my wife she also needed to drop a few pounds if she wanted to keep riding with me.. (that didnt go so well for me though)
