free website stats program Changing Cam | Harley Davidson Forums
Changing Cam
dlingle61
Getting ready to change cams in my 08 96", Have seen a part list before but can't find it today.:wall Could someone please list parts needed. Thanks Dave
Three "0" rings(one on the oil pump to sump suction hole, two in between the engine cam-plat. New snap-ring for front cam. Torrington engine side cage bearings to replace the INA's. Maybe a new gasket on the cam cover... (probably old will do just fine.)
New harley Hydraulic lifters IF You feel the need... I still used my stock ones at 17,000 miles when I put in the SE255 cams in my 09 FLHR.
SE SLENDER Taper adjustable pushrod set. (Best ones in my book)
SE p-rods 24 thrds per inch, set them at No less than 3 full turn.:D
? maybe exhaust gaskets,,,, I have used mine several times with No Leaks.
That is all I can think of.
