Thanks! I'm gonna check these out for sure, I've got that coming up in the not to distant future. I've heard on the Dynas it's not just the simple drain plug on the bottom like other models.
I wonder why they put a drain hole on the softails but not the Dynas? Are the forks that different?
No drain screws on 07 Dynas, you have to remove the top caps on the tubes, using a suction gun to remove the fluid:s
I did mine a couple of months back and replaced the oil using the SE fork oil (not the racing version) and it worked out Great. Yes, there is no drain hole.
