free website stats program Changing handlebar position | Harley Davidson Forums
kzoo
Banned
Per a suggestion in another thread here, I would like to lower the position of my handlebars on my '04 Heritage to try to alleviate some tendinitis in my left arm. My manual has not yet arrived (Have not checked yet today) so I will ask.
Anyone with a manual for that year softail that can give me torq specs for all the bolts to move my bars (tilt them lower) I would greatly appreciate it!
Thanks in advance.
My '07 FLHTC manual specifies 16-20 ft. lbs. If your bolts are 5/16" they should be the same. Note; the manual says to tighten the forward bolts until the top clamp touches the bottom clamp. Then tighten the rearward bolts to 16-20 ft. lbs., then torque forward bolts to 16-20. There will be a gap between top and bottom clamps at the rear.
Thanks. This weekends project..after the wife gets home from San Fran and I finish my honey do list!!!
It's important to keep the better half happy...specially since she doesn't like me having the scoot!!
*****************************************************:newsmile092:
I DID notice Your Location ,,,,,,,,,,,,,BATTLE CREEK Michigan:lolrolling:boxing
I used the old adage that it is easier to ask forgiveness...........
BC is pretty much a major mess now after the storm
looks like a war zone!!!!
Honey Do is a new Kellogg cereal.......not very healthy, but will keep you happy!!!
From my 04 Heritage manual.
Handle bar riser locknuts = 25-35 ft lbs.
Handle bar riser screws = 144-180 in lbs.
Hope it help.
HANDLEBAR AND RISERS
Removal
1. See Figure 2-83. Remove handlebar riser screws (1) and
riser caps (2). Remove handlebars.
2. One of the risers contains a ground spring (3) which provides
an electrical ground for the front turn signals.
Remove ground spring.
3. Remove riser locknuts (4) and washers (5). Discard locknuts.
4. Remove the risers (7). If necessary, remove the riser rubber
bushings (6) and rigid fork leg studs (8).
Installation
1. See Figure 2-83. If you removed the rubber bushings (6),
lubricate the outside of the bushings and install them in
risers (7). Be sure the lip on the bottom rubber is fitted
into the recess in the bottom of the riser.
2. Place the risers (7) in position over the rigid fork leg
studs (8).
NOTE
Be sure the risers are correctly oriented for the handlebars.
3. Install washers (5) and
new
locknuts (4). Tighten locknuts
to 25-35 ft-lbs (33.9-47.5 Nm). Place ground spring
(3) in one of the risers.
4. Place handlebars on risers and put clamps (2) in position.
Install screws (1). Make the gap between clamps
and risers even, front and rear. Adjust handlebars and
tighten screws to 144-180
in-lbs
(16.3-20.3 Nm).
Figure 2-83. Spring Fork Handlebars
8
6
7
6
4
5
X3
1. Screw (4)
2. Clamp (2)
3. Ground spring
4. Locknut (2)
5. Washer (2)
6. Rubber bushing (4)
7. Riser (2)
8. Rigid fork leg stud (2)
s0349x2x
Good info. It's interesting to see how specs. and procedures vary year to year and model to model.
be sure not to let the bars hit the tanks, with the wheel flopped all the way over.............bw
