Turk55
So I had to adjust my clutch on my 09 SG went through the procses of backing off the cable so their was slack then backed off the lock nut then adjusting screw. Next turned in screw till it just bottomed out and backed it off 1/2 turn, locked down the lock nut while holding on screw from turning next readjusted the cable. Now here the problem, after doing all this when I shift into gear the bike still wants to move what could be causing this?
