I installed headers and a K&N filter and had the bike 2004 flhrc1 maped by my local dealer. The code is P1356 and the check engine lights comes on and goes off at higher RPMs or under load carry a passenger. Any suggestion as to the problem?![]()
You beat me to it BUBBIE![]()
Thanks for the reply from all. I did change plugs before the problem started, used a recommended plug from a friend may need to change to another brand. The wire is seated good and the wire checked out good. Does any one have a brand that works as good are better than HDs Again thanks wish I had found this forum sooner.
I would just go with the Harley OEM plugs. Never found a need to go with any other aftermarket brands like Champion, NGK etc. Stock Harley plugs work just fine.:s
