free website stats program cold compression test | Harley Davidson Forums
can anyone please tell me how to turn engine over at starter (bypass ignition) so I can perform a cold compression test?
Thanks
Ron
Thanks
Ron
Why? I have never done that to perform a compression test. Make sure you have a fully charged battery; remove spark plugs; connect tester; hold throttle wide open and spin the motor through 5-7 revolutions or until the gauge stops moving. If carbureted, remove the carb from the boot before test.:hii
Bypass electronic ignition - - otherwise could burn it out.
