fabrozor
Hi all,
I watched this man on this video :
Head Gasket Questions - Video
The video is 09:55 long and after he said "you shall remove all the o-rings from the gasket because cometic gasket don't use o-ring", after 08:20 he also says 'you shall add some "permatex" (not sure about the name) a kind of jointing compound, around some holes of the head, to prevent fluids to insert between the layer of the gasket when the motor get up hot or get down cold".
Well ...
As i soon will mount some of those gaskets on my top end, i would appreciate your recommandations on the right way to use those gaskets.
Thank you for your help.
Well ...
