Depends a lot on what cams (other than stock) he has installed.
they were both 125 warm engine not hot a yes the throttle was open I thought it seemed a bit lowSeems a bit on the low side. Were the front and rear within 5 psi of each other? Was the test done with the throttle wide open? Carb or FI? Hot or cold motor?
and carberated alsothey were both 125 warm engine not hot a yes the throttle was open I thought it seemed a bit low
I am at sea level and the engine has 60000 miles on itIf it's a stock cv, remove the air cleaner and hold the slide up with your finger, throttle wide open and retest. You need to get max amount of air in to get the most accurate reading. A lightly modified motor reading should be up in the 150-160 range. You didn't mention how many miles are on the bike/motor and elevation. A motor at sea level will produce a little more psi than one in the Rocky Mountains. The higher the elevation the lower the psi reading may be.
the bike seems to run ok and they are screaming eagle flat top pistons they came with the kit probably cast and not forgedAny idea what pistons? Does the bike run OK? Squirt some oil in the cylinders and re do test does it change the numbers?
