Need some advice.. I have a 1999 FXDS-Conv Superglide, I just had the Geared Cams, lifters and all the other parts in there installed new. It is still at the shop and contemplating having the charging system replaced while it is there. Does anyone have any idea what is a dependable charging system for this bike, and what is a reasonable price I should pay. Might even attempt to do myself if I knew what to look for in a charging system. I believe this is the last snafoo to repair due to HD mistakes. :newsmile055:
What CAMS did you use? Are you still at 88 cu in or 95 big bore?
NOT KNOWING YOU OR YOUR BIKE. mileage on it? What shape its in , paint and tins.
ONE owner or ? , YOU bot new..?????
If YOU have MONEY to TOSS at it, I would of strongly recommended to change OUT the OIL PUMP and CAM SUPPORT PLATE if not already...
NOT knowing what PARTS you meant by
"and all the other parts in there installed new..." what are the OTHER NEW PARTS....???
A lot more information is need FROM YOU,,,,,
UNLESS you only wanted to know about A DEPENDABLE CHARGING SYSTEM TO USE???????
ANSWER YOUR QUESTION dependable ONLY ,
I would say STICK TO HARLEY STOCK REPLACEMENT PARTS by that I mean replace ALL the stator and outer mag rotor using Parts from HD, as they have improved with the better NEWER replacement parts for that year ...
NOW IF YOU WANT MORE INFORMATION from ME!
YOU can read a lot about the 1999/2000 bikes if you WEED THRU some of my post... Click on my name BUBBIE to the left above my title and bike,,,, YOU will get information ,,, LOTS of stuff about that year and MODEL ... I owned a FXDS 2000 EARLY model year that was full of NEEDED TO CHANGE OUT ITEMS...
I put over 50,000 on a gear drive REBUILD and made a very HIGH PERFORMANCE motor... 6 speed tranny and MUCH MORE.. YOU will learn a lot about YOUR 1999 by going there... WAY TOO MUCH STUFF TO REPEAT HERE... for the many who have HEARD IT ALL BEFORE.......
