Rock Chalk
I've added 10" Yaffe bars along with blacking out some pieces. Everything's back together, but this weekend on some test drives, I notices that the clutch will not engage when I have the bars turned to the far right or left. It seems its probably getting pulled on at the crash bar. The answer is to probably get a longer clutch cable (i used stock), but is there an adjustment that can be made to correct that rather than change?
If i do change....is that a complex endeavor?
Other question is regarding the front wheel. How "free" should it spin on it's own. When i had it up on the jack and put it and the brakes back on, i noticed that it doesn't really spin freely? Should it? And did it not get something back on properly?
thanks all,
steve
09 flhx
thanks all,
steve
09 flhx
