Once you figure out the power issue you'll have to follow these steps to marry the cruise to your scoot.
Also see here for the cruise diagnostics and codes.
Cruise Control Diagnostics and Codes - Harley Davidson Community
If you were doing a throttle cable adjustment it is possible that you may need to do an initialization . Here is the scoop from the service manual:
The engine should be at normal operating temperature and throttle and idle cables should be correctly adjusted. To set the correct cable lash proceed as follows:
1. Push the Cruise Switch on the right handlebar to RESUME and hold it.
2. Turn the Cruise ON/OFF switch to ON.
3. Turn the Ignition switch to IGNITION.
4. Start the engine. The green Cruise Enabled/Engaged lamp in the speedometer will illuminate.
Wait 3 Seconds for the lamp to go off.
5. Release the Cruise Switch from the RESUME position
6. Push the Cruise switch to RESUME and hold. Cruise will pull in cable until change in RPM is detected. The number of motor steps required to rev the engine is stored in memory.
7. After engine revs and Cruise Enabled/Engaged lamp is extinguished release the Cruise Switch from the RESUME position.
8 Turn the ignition switch to off.
Some possible causes for improper operation are
If the cruise engaged lamp does not illuminate at all, check for one or more of the following conditions:
a. SET/RESUME switch faulty or not wired correctly.
b. Broken or pinched wire to SET switch or cruise module.
c. Cruise engaged lamp burned out or miswired. Lamp is turned on by module supplied ground.
d. Main 10-place connector not plugged into cruise module.
e. Faulty cruise main switch and associated wiring.
f. No module ground at Terminal E of 10-place module connector.
g. Brake light on constantly.
h. Throttle cables too tight.**
i. Bad cruise control fuse.
