Have 98 ultra converted from mm to mikuni hsr 42. Bike runs excellent in morning hrs. however, in afternoon anywhere from about 85 degrees and above the bike will start cutting out around 70 mph. warped fuel line in heat shielding. running twin tec ignition module, single fire coil, ign power relay and voes. did have to build wire harness to coil, used 18g wire. appreciate any ideas of what may be causing this
