Yes, I had them work on my 09 Ultra during Biketoberfest in Daytona. I had them put on Rinehart Slip-ons, K&N Air filter, Power Commander, complete fluid change and added their new magnetic drain plugs (3) also installed new NGK Iridium spark plugs and ran on the Dyno and wow what a difference. Increased HP and Tourque and runs cooler. Chris the owner is great and his mechanics do great work. They treat your bike like their own! Chris is a perfectionist when it comes time to setting everything up on the dyno. I went back to meet up with them again at the Leesburg Bike Fest and had them install Vance and Hines Dresser Duals, added their JetScream breather and ran on the dyno again. Just by going true dual and adding the JetScream bike is running 30 degrees cooler than first dyno setup in October. From my experience with the dealers and the lack of them doing what they are suppose to do during a so called tune up, no one else will touch my bike except Chris and Cycle Solutions. I will see them again in the fall @ Biketoberfest and have them change the fluids. Check out their web and also the you tube videos.
Ride safe,
Paul
