Plainsman
The D&D Fat Cat that came on the 06 Ultra I just bought had a standard baffle in it. Just a louvered 2&1/4" louvered inner pipe with a steel cylinder welded around it. Reading descriptions I found the Quite Baffle was the same inner louvered pipe with packing around it. It was reported by many the QB would lower the pitch and loudness of the pipe without hurting the torque & H/P of the standard baffle. The QB is over $150.00 so being cheap I removed the standard baffle, cut the outer can off with a plasma cutter and installed a ceramic muffler wrap. The results was great, a real low throaty rumble at moderate throttle but won't leave you unnoticed when you crank the throttle on. I can't feel any loss of power by the seat of the pants. I would recommend the Fat Cat with a Quite Baffle to anyone with up to a 103" with stock heads and mid cams
