2001 Trouble codes for Magnetti Marelli EFI.
The codes are:
11 = Trottle position sensor
12 = Barometric pressure sensor
14 = Engine temperature sensor
15 = intake air temp. sensor
16 = battery positive voltage
23 = front injector
24 = front ign. coil
25 = rear ign. coil
32 = rear injector
33 = fuel pump relay
35 = Tachometer (doesn 't apply on FLHR/C-I)
41 = Crankshaft position sensor
42 = camshaft position sensor
44 = bank angle sensor
52, 53, 54, and 55 = ECM problems requiring new ECM
56 = Crank position sensor/Cam position sensor signal error
Turn ignition switch on and off three times, then leave on the fourth time. Engine light will flash rapidly, stop then flash slowly. Count the slow flashes and record them. After first slow flashes will come another set of slow flashes which will be the second number. Then rapid flashes followed by slow flashes if there is more than one code. It will repeat the output until the ignition is turned off.
