I believe I read on this sight that the Dyna neck is open to the frame tubes.You would be filling the entire frame with grease.
Anyone ever tried drilling and tapping a grease zerk in a dyna neck?
I need to replace my neck bearings and was thinking of doing this while I had it apart.
If you have the know-how to replace the bearings, you have the know-how to seal off the frame.
Just close it off. Can't be that involved to do it.
Breeze, I'm on a mission now. My bike only has 7K miles on it but I was thinking of changing the fork oil with the next couple of months. And once the legs are pulled, I would only be an hour away from having the lower triple tree out. From there I would only be an hour away from having a tapped hole and zerk fitting in the neck and only an hour away from having the frame sealed off....and only an hour...and
See how my crazy mind works?
