It is a Dakota clone. These knock-offs are getting harder to find and I recommend if you are going to this style digital, go with the Dakota. The display is green LED and does not show up well in direct sunlight. These speedos may cause headaches with warranty issues because they do not recognize communication from the ECM and do not display error codes.
Another option for you might be a different speedo from Harley to replace the OEM unit. Harley offers a replacement speedo with a tach which is a plug-n-play swap. This unit also offers hundreds of color/light combinations which the user can set-up to meet their liking. The run about $400, but cheaper than trading in the bike. Check out the accessories section of Harley's website.
