classic08 Member Nov 12, 2009 #1 I was wondering if the fang wheels for the dyna fat bob will fit on my 08 electraglide. The wheels are 16 but are they too wide.
Bud White Well-Known Member Retired Moderators Nov 12, 2009 #2 the front wheel is only one brake rotor on a dyna no ? so that would have to be fixed but i think the fat bob tire is same as a EG
classic08 Member Nov 12, 2009 #4 the spacing is what i was wondering about.The axles should be ok even if i have to change bearings right?
Bud White Well-Known Member Retired Moderators Nov 12, 2009 #5 the touring uses a 25mm axle and bearing you should be able to swap them you can also buy a wheel install kit that has the spacers
classic08 Member Nov 12, 2009 #6 no abs that sound easy lets hope Last edited by a moderator: Nov 12, 2009
Bud White Well-Known Member Retired Moderators Nov 12, 2009 #7 whats the part # of the wheel and what does HD say it will fit
Bud White Well-Known Member Retired Moderators Nov 12, 2009 #8 aint gonna fit then.. probley has to do with rotor and rotor holes .. as the touring uses a bigger rotor since 08 than anything else when they went to the brembos
classic08 Member Nov 12, 2009 #9 the part numbers are front 43265-09 rear 43268-09. say they will fit fxdf man that (EDIT) i really like them wheels A Friendly Reminder - Harley Davidson Community Last edited by a moderator: Nov 13, 2009
