RibEye
Senior Member
I am an electronic and software engineer, so forgive my technical terminology. I am having an issue that requires a process of elimination. The issue is far too intermittent to allow an easy determination of fault.
I do not believe my problem is the TFI, but I want to eliminate it as a possibility. It is fairly difficult to physically remove it, and I don't want to just turn some pot settings. I want to eliminate its function, but leave it installed. Is that possible?
I have been told that you can just disconnect its ground wire. That makes some sense to me, in that, the injectors are low-side driven, and the TFI injector drive contribution could easily be hard-wire OR'd with the ECU injector drivers. Is this true?
In any case, is it safe to disconnect the TFI ground wire and run it that way for a week or so? My problem is very intermittent, but significant when it occurs, and I may need time to see it occur with the TFI out of the circuit. Sometimes the issue (stuttering and misfiring) does not occur for 70-90 miles.
Thanks in advance,
Rich P
Thanks in advance,
Rich P
