free website stats program Electra glide standard 2005 hydraulic clutch kit | Harley Davidson Forums
Hello guys,
I'm searcing for my old lady 2005 electra glide an hydraulic clutch kit, but OEM part number 46448-05 is not avaible on hd Europe. Do you have suggestions???
Thanks for help
Are you looking for lighter pull? If so, there are a couple of things you can do that are more economical modifications that converting to a hydro clutch.;)
Before you change out a lot of parts you might try putting on a new clutch cable and see if that helps.
HDDon's suggestion is a good one. OEM cables are Teflon lined and should not be lubricated because lubricant can cause the cables to drag in the sheath. If looking for a lighter pull a new cable might help but the pull won't come close to the pull of a hydraulic clutch. Suggest that you replace the clutch cable and install the HD Reduced Effort kit (PN 36808-06) which includes a new clutch spring and inner/outer ramps and was an upgrade in the '06 models. If that doesn't achieve the desired results, next and more costly step would be installing a VPC clutch "hat".
