This morning I turned the key ON on my 2006 Ultra. Everything was fine until I pushed the start button. As soon as I did the entire bike went dark. When I let up on the button nothing came on. I turned the key off and back on and nothing came on. I turned the key to the ACC position and the switches came on very dim. Nothing else worked. I checked all the fuses, there all good. I connected a battery charger and the system powers up, except for the small engine symbol on the tach. I also don't hear the fuel pump running. The bike won't turn over, I get a popping noise comming from under the battery when I try to start with a 50 AMP battery charger connected.
