jigglestick
My '03 Road King has developed a knock, mostly at idle. I think that I have narrowed it down to the Compensator Sprocket and Cam. I am about to remove it and give it the once over. I think that the springs are either weak or broken after 72,000 miles.
My question is this: With the engine off, are the Compensator Cam and Sprocket supposed to be tight together? or are they supposed to have a space between them? In other words, both the cam and the sprocket have, what I would call, ramps that sort of mesh together. Allowing the cam to slide on the shaft when torque is applied. Just not sure if they should be together for a starting point or apart. I am inclined to think that they are supposed to be together. Mine aren't. I have about 3/8" gap between the two with the motor off.
Any help would be greatly appreciated.
