hi i got a 1996 dyna , had it for a year now, and done the usual mods.
Andrews 46 cam,
Hooker pipes,
S.E air fitter,Ignition Module,Performance Coil,
JE 10.5:1 compression pistons,
Mikuni HSR-42
Now it come to the heads, i had a mate do a 5 dergee angle valve job. the question is now is it worth getting performance valves or S.E heads. and if i do how will it effect low, mid range power.
I mate of mine said if i get performance valve or S.E heads it take away low mid range power and moves it to the high end range is this right.
Andrews 46 cam,
Hooker pipes,
Mikuni HSR-42
