RetiredJake
Junior Member
I was doing the 15K service on my '08 FLHTCU and got to the rear sprocket inspection. Found the chrome gone from the teeth and valleys on the sprocket. Dropped the rear wheel to get a better look and found the teeth to be worse than I thought, and the sprocket bearing in bad shape. The bearing shield was loose and severly worn, and it looks like a ball is missing from the bearing. The belt itself looks great except for some small cracks across the width in the valleys, no abnormal wear apparent.
Any history of problems with the IDS/sprocket assembly on the '08 Touring bikes? Any chance this is a warranty issue?
Thanks for any help/info. :newsmile077:
